1995 Honda Civic brake rotor replacement
80,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVESHMO
When replacing disc pads, what measurements do I need to check on a rotor to see if I can keep the rotors as is, turn them, or have to replace them? I have to measure the thickness of the rotors and check for scoring. If I need to check waviness as the rotor is turning or cupping from the inner part to the outer part, how do I do that?
Mar 7, 2009 at 12:42 PM
KHLOW2008
  • 41,812 POSTS
Hi daveshmo, When the surface of the rotors are smooth and you do not have vibrations when applying the brakes, you need not bother about the rotors. Here are the specifications.
https://images.2carpros.com/forum/automotive_pictures/192750_DiscBrake95Civic_1.jpg
To test runout you would need a dial gauge
Mar 16, 2021 at 4:06 AM
DAVESHMO
Thank you very much
