1995 Honda Civic brake lights
139,000 MILES • 4 CYL • 2WD • MANUAL
ROBCUEVAS84
my brake lights do not illuminate when pedal is depressed but rear lights come on when lights are on in the repair manual it speaks of a fuse box for the abs but i cannot locate this if that is where the problem is do you guys have any suggestions of where to locate or if its not that than what maybe thanks
Mar 6, 2009 at 12:56 PM
F4I_GUY
  • 3,302 POSTS
The ABS fuse is not for the brake lights.
If you look on your fuse cover (both interior and engine-bay) there is a labeled diagram on the cover that will tell you where each fuse is.
Another possibility would be a faulty brake switch. Goodluck.
Mar 6, 2009 at 1:39 PM
