1995 Honda Civic bog when accelerating or goin up hill
160 MILES • 4 CYL • FWD • MANUAL
DRO85
  • 7 POSTS
hey i just rebuilt my 95 civic vtec virtually everything has been replaced, i have 160 miles on it. i changed spark plugs, wires, used dizzy, map, tps, ait, ect, fuel filter and checked timing with light. it boggs or stutters when accelerating around low rpms or up hill after the hill it will bog worse??i have no check engine lights or codes. when i give it more gas it bogs and smells like gas then takes off, BUT DOES NOT JERK???. when it bogs it will go through rpms but wont accelerate much it only acts up on some take offs. any help would be greatly appreciated!!! ty :)
Oct 24, 2010 at 11:30 PM
KHLOW2008
  • 41,814 POSTS
Hi dro85,
If engine is equipped with EGR, try disabling it by plugging the EGR valve vacuum and test if problem goes away.
Oct 25, 2010 at 1:40 AM
DRO85
  • 7 POSTS
ty for ur help ill try it :D
Oct 25, 2010 at 10:40 AM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Let me know how it goes.
Oct 26, 2010 at 12:11 AM
DRO85
  • 7 POSTS
ty but does the pcv do the same thing as the egr? lol i have read a couple articles that say i dnt have an egr??
Oct 26, 2010 at 12:19 PM
KHLOW2008
  • 41,814 POSTS
Some models are equipped EGR with whereas some are not so I am not able to say if yours has any.
Faulty PCV would result in higher idling speed but would not cause the bogging.
Apart from EGR, othere components that can cause power losses are:
1. Ignition coil.
2. Spark plug wires.
3. Fuel pressure.
4. TPS sensor.
5. Ignition timing
6. Valve timing, (timing belt installation).
7. O2 sensor.
Oct 27, 2010 at 2:32 AM
DRO85
  • 7 POSTS
ty for ur time!! :D i was reading on the internet that a fuel pump going out could cuase bogging while driving or up hill. do u think this could be the problem?
Oct 27, 2010 at 11:04 AM
KHLOW2008
  • 41,814 POSTS
It is possible. Get the fuel pressurre checked to see if they are within specs.
Oct 27, 2010 at 11:13 AM
DRO85
  • 7 POSTS
sounds good! also forgot to mention it usually loses power after driving for more than 15-20 minutes. i will check this out!
Oct 27, 2010 at 11:19 AM
