1995 Honda Civic Antifreeze levels dropping
175,000 MILES • 4 CYL • 2WD • MANUAL
DANI_ELLE_2748
The antifreeze levels keep on dropping in my car. There are no holes in the hose (that we know of...we just got the car checked at Oil Can Henry's..the whole deal) and there is no puddles where it would be leaking. I have to keep filling up the antifreeze every 3 weeks because it disapeers from my car.
Mar 3, 2008 at 7:44 AM
BLACKOP555
  • 10,386 POSTS
make sure it is not leaking out of the water pump via the pulley or around the mating surfaces. if that is good check to see if its overflowoing from the resevoir when the hot engine is turned off.
if not then you probably have a internal leak.
Jan 28, 2021 at 1:37 AM
