1995 Honda Civic acceleration
111,000 MILES • 4 CYL • FWD • AUTOMATIC
LISA1995
my car starts fine however when I step on the gas to go the car hesitates and supters and move about 10 to 20 mph before accelerating to a normal speed
Jul 11, 2010 at 9:03 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 11, 2010 at 9:05 AM
