1995 Honda Civic ABS light on
142,000 MILES • 4 CYL • FWD • AUTOMATIC
MARCOPELL1
  • 5 POSTS
Hi, thanks in advance for taking the time to answer my question. As you can already tell my ABS light keeps coming on. I already cleaned the sensors and checked the gears they are clean and free of residue. I measured the air gap between the gear and sensors. The next test I was going to make was with the multimeter looking for volts and OHMs. How much should I be looking for on each one. If that test comes out good what could be other causes of this problem. Thanks again! Take care
Apr 14, 2009 at 4:17 PM
F4I_GUY
  • 3,302 POSTS
First you must retrieve the code and post it up for us to help you out.
And for wheel speed sensors, if the reading is infinite, then the sensor is open and it needs to be replaced.
Apr 17, 2009 at 11:00 AM
