1995 HONDA CIVIC 84000
EGNATIA
1995 HONDA CIVIC 84000 MILES.
PUT SOME 91 OCTANE GAS IN AT A LOW BUDGET STATION. CAR STARTED TO SLUMP AFTER A COUPLE DAYS AND THEN DIED. CHANGED FUEL FILTER. STARTED UP,BUT NOT TOO MUCH POWER. CHOKING! PUT IN SOME INJECTOR CLEANER, GOT A BIT BETTER, STILL NOT GOOD. DRIVE A BIT AND THEN EVENTUALLY DIES OUT. THE CAR HAS BEEN IN STORAGE FOR A WHILE BEFORE I PUT IN GAS. ANY SIMPLE FIX? SHOULD I PUT SOME CHICKEN SOUP IN THE TANK NEXT? PLEASE LET ME KNOW IF I SHOULD TRY SOMETHING. THANKS! HARIS :shock: :shock:
Apr 3, 2007 at 8:07 AM
BRUCE HUNT
  • 3,754 POSTS
You can try the cleaner but don't OverDose on the stuff. You can try an antigel for gasoline engines. But I think you may have to keep the tank filled with good fresh gas and let it work the problem through. After another few weeks I might even suggest replacing the fuel filter again. This tough to work through and erffects the pump, injectors, etc.
Apr 4, 2007 at 2:06 AM
EGNATIA
THANKS! I WILL TRY. GREAT CAR......BUT THIS STUPID SITUATION IS DRIVING ME CRAZY!
:shock:
Apr 4, 2007 at 5:49 AM
