1995 Honda Civic 1995 Honda Civic Powerr Steering Help
174,440 MILES • 6 CYL • FWD • AUTOMATIC
PERRIN19
I drive a 1995 Honda Civic Ex Automatic
and i just started having a problem with my power steering. when i start the car it make a whine noise when i start the car and try to turn the wheel. i put a different pump on their to see what will happen i started the car and it didnt make a noise. so i jacked the car up on both sides and started to bleed the power steering after i did that i lower the car and try to turn the wheel it was hard to turn and i noticed power steering fuild coming out the top of the reservior what did i do wrong did i bleed the system wrong. please help i going crazy trying to find the problem
P.s i took it to 2 mechanic and 1 said its the rack and pinion. and the other mechanic said its the power steering pump/
Aug 11, 2010 at 3:43 AM
DOCFIXIT
  • 18,828 POSTS
Hi Diffrent pump mean rebuilt,new or junkyard? was pump for that year and model? was steering free off ground?
Let me know
Thanks for donate
Aug 11, 2010 at 5:26 AM
PERRIN19
[quote:8f3f51f06d="Docfixit"]Hi Diffrent pump mean rebuilt,new or junkyard? was pump for that year and model? was steering free off ground?
Let me know
Thanks for donate[/quote:8f3f51f06d]
the pump was from the junkyard. yes it was for my model. and what do you mean free off ground.
Aug 11, 2010 at 6:56 AM
DOCFIXIT
  • 18,828 POSTS
Turns easy when you had it jacked up if yes then I agree with second Tech pump faulty
Aug 11, 2010 at 7:00 AM
PERRIN19
[quote:603be256e0="Docfixit"]Turns easy when you had it jacked up if yes then I agree with second Tech pump faulty[/quote:603be256e0]
yes it turned easy when the car was off the ground. did i bleed the system right by turn the wheel in both directions until it stops turning ? wat are the step when bleeding the power steering system i think i might had did something wrong during bleeding
Aug 11, 2010 at 7:21 AM
DOCFIXIT
  • 18,828 POSTS
You bleed it correctly the way to find out if pump need to check pressure of pump output
Aug 11, 2010 at 7:47 AM
PERRIN19
[quote:8d6a39380f="Docfixit"]You bleed it correctly the way to find out if pump need to check pressure of pump output[/quote:8d6a39380f]
how do i check pressure of pump output
Aug 11, 2010 at 8:09 AM
DOCFIXIT
  • 18,828 POSTS
Need a power steering or trans pressure that can go up to 1000 psi. it Tees into high pressure hose to pump fitting
Aug 12, 2010 at 8:25 AM
