1995 Honda Civic
SUPERSPORT1970
  • 1995 HONDA CIVIC
Engine Performance problem
1995 Honda Civic 4 cyl Two Wheel Drive Manual
I pulled the distubiter out now I can not get it back in and get it to start
Friday, April 18th, 2008 AT 3:55 PM
BRUCE HUNT
  • 3,754 POSTS
The distributor shaft only goes in one way and can not be confused. Line up the shaft with the slot on the camshaft and you will note the offset of the slot. You will need to get the #1 plug wire on the correct terminal of the distributor.
Saturday, April 19th, 2008 AT 11:18 PM
