how do you get the handle off the door to get to the inside to fix the window the handle is for the window
Feb 26, 2009 at 10:20 AM
HONDATECH74
MEMBER
[quote:9fdca5c338="katkatt"]Interior problem
1994 Honda Civic 4 cyl Two Wheel Drive Automatic 165000 miles
how do you get the handle off the door to get to the inside to fix the window the handle is for the window[/quote:9fdca5c338]there is a "C" clip that holds the window crank handle on, if you use a hooked pick between the handle and the small plastic cover you can pull the clip out.
