1994 Honda Civic White smoke from exhaust pipe
152,000 MILES • 4 CYL • 2WD • MANUAL
GMCRAMMIT
  • 7 POSTS
I started my car this morning and noticed a plume of white smoke coming from my exhaust. My neighbor walking by stated that it was probably an oil leak. I have had a problem with my coolant reservoir boiling/steaming the last couple of weeks and engine temp gauge almost approaching H. I have added coolant and water to keep it from overheating but levels have dropped throughout the week. Any ideas?
Jun 23, 2008 at 1:53 AM
DOCFIXIT
  • 18,828 POSTS
I believe you have a blown headgasket runnig hot with an alluminum cylinder is certain cause of failure.
Check oil for water ie oil will look like a chocolate shake. Pull plugs pressurize coolant system wait a while then crank if water comes out plug holes you have verefied a headgasket failure.
Hope this helps
Jun 23, 2008 at 2:09 AM
GMCRAMMIT
  • 7 POSTS
Thank you for your response. How do you pressurize the coolant system?
Jun 24, 2008 at 2:53 AM
DOCFIXIT
  • 18,828 POSTS
Need a pressure tester major tool supliers have. Probably be cheaper to go to a shop have them check it out.
Jun 24, 2008 at 3:02 AM
GMCRAMMIT
  • 7 POSTS
Thank you again for your response. What would be the result of driving with a blown head gasket? I know it can't be good for my engine but don't have the funds right now to fix. Have you ever used or heard of anyone using "Heal-A-Seal" or "Bar's Leaks Head Gasket Repair" or any other head gasket repair formula in a bottle?
Thanks,
Greg
Jun 30, 2008 at 5:23 AM
DOCFIXIT
  • 18,828 POSTS
Those products are like putting a bandaid on a laserated artery. Save your money when your neighbor notices the smoke you are way past snake oil. If your oil looks like a chocolate shake and you keep driving the engine will self distruct. Water is not a good lubricant. Park it take the bus.
Good luck
Jun 30, 2008 at 11:49 PM
