I would like an estimate on how much it would cost to pay a shop to replace the water pump on my 94 honda civic. The pump is timing belt driven.
Also how much to replace the clutch
Saturday, June 13th, 2009 AT 1:06 PM
ROSSCOSUMBICH
MEMBER
Honda water pump labor can be round 250. With parts 350 depends on the shop must replace belt also check 4 oil leaks whle ur in there
SPONSORED LINKS
Saturday, June 13th, 2009 AT 1:24 PM
AJHT50
MEMBER
Thanks. The rear gasket is the only oil leak which im guessing is because the clutch is about to go out. Im just trying to decide if its worth the repair or not
