1994 Honda Civic starting
RICKAU
Electrical problem
1994 Honda Civic 4 cyl Two Wheel Drive Manual
the car was running fine i shut it off and started it up several hours later it was runnng for a second then died and hasnt started since. it is getting gas and spark i pulled the plugs and checked it.
Jun 24, 2008 at 8:06 AM
KHLOW2008
  • 41,812 POSTS
Hi rickau,
How sure are you that gas is available at the injectors or fuel rail?
Did you test the pressure?
If fuel pressure is low or none, then you need to check the fuel pump or main relay.
Jun 25, 2008 at 2:14 AM
