1994 Honda Civic Squeaking
12 MILES • 4 CYL • FWD • MANUAL
KILBYBEN
The engine is freshly rebuilt. Everything seems to be running fine except a slight squeaking noise after the car warms up a bit. Running about 15-20 mins. Coming from the front of the engine. Only belts on engine are timing and alternator. All are new. New water pump, oil pump and belt tensioner. Worried it might be a bearing. Any ideas. Doesn't make sound when car is cold
Jun 26, 2010 at 5:51 AM
F4I_GUY
  • 3,302 POSTS
Take off the alternator belt and run the car with a battery charger on it. See if the noise is gone. If it is, you have a loose belt or worn alternator bearing.
Jun 27, 2010 at 2:10 PM
