Spark plug firing order on distributor cap
158,000 MILES • 4 CYL • FWD • MANUAL
HANNAHBERARDI
We need a diagram of where cylinder 1 goes on the cap for a 94 honda civic.
Thank you
Mar 10, 2010 at 11:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_377.jpg
Mar 10, 2010 at 11:49 AM
  • 75,988 POSTS
1.5L
https://images.2carpros.com/forum/automotive_pictures/12900_c2_26.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_c1_28.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_home_16_1.gif
Mar 10, 2010 at 11:51 AM
GIRLW/WRENCH
after finding one of my sparkplug wire casings melted inside i replaced all plugs wires distrubutor and head gasket. Ive double checked the firing order but still cant get the car to turn over. could this be a timing issue and if so ....what next?
Oct 4, 2018 at 4:04 AM (Merged)
FISHERMAN
  • 937 POSTS
once you have the correct firing order find out when the piston its in the upper position on cilynder 1 and check if the rotor its ponting to that spark plug.. or you can do it the easy way:
Move or rotate the complete set of cables in the same order one spot at the time and crank the engine until you find the correct position do you know what i mean?
GIRLW/WRENCH
[quote:b509f279f8="fisherman"]once you have the correct firing order find out when the piston its in the upper position on cilynder 1 and check if the rotor its ponting to that spark plug.. or you can do it the easy way:
Move or rotate the complete set of cables in the same order one spot at the time and crank the engine until you find the correct position do you know what i mean?[/quote:b509f279f8]Thank-you fisherman, im going home at lunch to give it a try.
FISHERMAN
  • 937 POSTS
Let us know!
(rotate the wire set on the distribuitor cap)
GIRLW/WRENCH
(rotate the wire set on the distributor cap)
Thank you! My car has never run better thanks to your patient instructions. I guess I am officially a shade tree mechanic! 8) lori
