HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Serpentine Belt
Replace/Remove
1994 Honda Civic Replacing the alternator's belt
REZARENEE
MEMBER
1994 HONDA CIVIC
4 CYL
FWD
MANUAL
17,600 MILES
Which way is the easiest way to replace alternator's belt?
Sunday, June 14th, 2009 AT 8:37 AM
KHLOW2008
MECHANIC
Hi rezarenee,
I don't believe there is any easiest way, just the proper way.
Remove the power steering belt, if equipped.
Remove the AC belt.
Remove the alterator belt.
SPONSORED LINKS
Sunday, June 14th, 2009 AT 11:06 AM
Please
login
or
register
to post a reply.
Related Serpentine Belt Replace/Remove Content
Can Overheating After Replacing Water Pump&timing...
Honda Civic 2000 Dx Hatchback. Mileage 101,000. I Recently Had The Timing Belt And Water Pump Replaced. Unfortunately The Water Pump Was...
Asked by
demetris
HONDA CIVIC
GUIDE
Serpentine Belt Replacement
Need to change your serpentine belt? This is an easy job in most cases. There are several names used to describe a serpentine belt, including: drive belt, poly-v belt, multi...
2004 Civic- Do I Have To Replace The Water Pump When I...
I Have A 2004 Honda Civic With 95,000 Miles. Now That It Is Getting Close To 100k I Want To Get The Timing Belt Replaced, And My Owner's...
Asked by
s390325
1 ANSWER
2004
HONDA CIVIC
1998 Honda Civic Power Steering Belt Replacement
1998 Honda Civic Front Wheel Drive Manual I Am Trying To Replace The Power Steering Belt So My Car Can Pass Inspection But Im Not Sure...
Asked by
meganmaccabee
1 ANSWER
1998
HONDA CIVIC
1996 Honda Civic Ac Belt Replacement
1996 Honda Civic 4 Cyl I Need To Replace The Ac Belt On My Daughters Car. The Routing Of The Belt I Believe Goes Around The Lower...
Asked by
stich40
1 ANSWER
1996
HONDA CIVIC
Quot;a/c Belt Removal"
1992 Honda Civic Dx.102000 Mi.--There Is An A/c Belt That Is Giving Me Problems To Removing Due To A Bracket Just Above The Belt In Which I...
Asked by
hern615
1 ANSWER
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Serpentine Belt Replacement Chrysler
Serpentine Belt Replacement Ford Contour
Serpentine Belt Replacement Mercedes Benz
Online car repair manuals
