1994 Honda Civic Inrument Panel
166,742 MILES • 4 CYL • FWD • AUTOMATIC
JEYJAH
When I turn on my lights at night my intrument panel does not light up, check the fuses everything is find, so I think it may be the bulb. If so how do I take off the instrument panel to replace it or could it be something else is wrong?
May 21, 2009 at 9:57 PM
F4I_GUY
  • 3,302 POSTS
Remove the two philips screws for the cluster bezel. Remove the bezel, now you can access the 4 screws that hold the cluster in. Remove the cluster and test for power and ground.
Apr 7, 2021 at 6:20 AM
