1994 Honda Civic in need of assistance plz!!!!
175,000 MILES • 4 CYL • FWD • MANUAL
HONDAGUY13
my car is still up to the same old games. when i first start the car up the motor surges up and down until the car is warmed up. people say its a vacuum leak but i just cant find where it is at. also, when my car is warmed up, the rpms will idle at about 1000, then drop all the way to 0, then if i give it gas, it stays right at 1000, then drops again. it only does it when the car is warmed up. if you know why this is happening please give me detailed info on how to fix.
thank you all very much.
Sep 1, 2010 at 7:19 PM
LARRY6354
  • 20 POSTS
Is your C.E.L. on.Check engine light. It probably is.
You may have any number of problems ,you first need a scan at your local part dealer. Auto zone,rileys,advance etc. You've either got an IAC problem or your ambient air temp sensor and coolent sensor are argueing with each other.Get a scan and get back w/me.
Sep 2, 2010 at 8:01 AM
HONDAGUY13
no the check engine light is not on i will get back with you when i get a scan done on it. thank you very much.
Sep 2, 2010 at 10:54 AM
LARRY6354
  • 20 POSTS
I'll be here!
Sep 3, 2010 at 6:01 AM
