1994 Honda Civic heater/ ac control panel light
190,700 MILES • 4 CYL • FWD • AUTOMATIC
DEWAYNE33US
How do you change the heat/ ac control panel light /on a 1994 Honda Civic LX?
Jan 30, 2010 at 5:35 PM
KHLOW2008
  • 41,812 POSTS
Hi dewayne33us,
You would need to remove the control panel to change the bulbs which are plugged and/or twisted in.
HEATER CONTROL PANEL
Removal & Installation
Remove center lower panel (4 screws).
Remove radio.
Disconnect air mix control cable from linkage at bottom of heater unit.
Remove heater control panel (3 screws).
To install, reverse removal procedure.
Adjust air mix cable and heater valve cable.
© 2008 Mitchell Repair Information Co., LLC.
Feb 3, 2010 at 5:09 AM
