1994 Honda Civic Fuel gauge
150,000 MILES • 4 CYL • FWD • AUTOMATIC
YOSHI-C
hi there i just brought a 94 honda civic and the fuel gauge isnt working,ive had a look at all the fuses and they seem to be ok.do you know what else could be the problem?and if i have to replace the gauge itself,is that very difficult?
Thanks very much
Josh
May 12, 2008 at 1:24 PM
KHLOW2008
  • 41,814 POSTS
There is a sending unit in the fuel tank which could also be the cause. Remove the rear seats to get to the service hole and check the wiring. Color of wire from gauge to sending unit should be yellow/green. earth it with ignition on and see if gauge works, if yes, the sending unit is the fault. If you need to replace the gauge, then you need to remove the meter assy which is not very difficult.
Apr 7, 2021 at 6:29 AM
