1994 Honda Civic Car stereo and ignition switch connections
BOBBYRUBIO
Electrical problem
1994 Honda Civic Front Wheel Drive Manual
A friend recently replaced my ignition switch for me.
He didn't re-connect all the nodules to the switch, so my car stereo no longer works. I am trying to find out what goes where so that my stereo will get power again.
Thank you!
Rob-
Jun 9, 2008 at 5:24 AM
KHLOW2008
  • 41,812 POSTS
Hi bobbyrubio,
The ACC wire from the ignition switch is White/Black. Btw did you check the radio fuse?
Jun 10, 2008 at 4:00 AM
BOBBYRUBIO
Great,the wire/nodule that needs to be connected is the black/white one?
So far so good.
Where (what slot) does it go in the ignition assembly?
By the way, if I recall the fuses were all o.k.
Rob-
Jun 10, 2008 at 6:29 AM
KHLOW2008
  • 41,812 POSTS
Hi bobbyrubio,
Let me know the following.
How many pins at ig switch?
What are the wire colors?
Jun 10, 2008 at 7:09 AM
BOBBYRUBIO
I'll have to check exactley how many pins and the colors. I think there were about 5 pins, and I think I remember yellow, black, white...
Again I'd have to check.
Jun 10, 2008 at 7:59 AM
KHLOW2008
  • 41,812 POSTS
Hi bobbyrubio,
If 5 pin the colors should be as follows.
White/black = ACC
White = Battery 12v
Black/yellow = IG1
Yellow = IG2
Black/white = starter.
2 pin side is Ig1 and Ig2
3 pin = Batt, ACC, Starter.
Jun 10, 2008 at 11:09 PM
BOBBYRUBIO
Sounds right!
Now I have to know where the "acc" nodule connects at the ignition assembly.
Thanks so far!
Jun 11, 2008 at 4:36 AM
KHLOW2008
  • 41,812 POSTS
Hi bobbyrubio,
ACC is centre of 3 pin side.
Jun 11, 2008 at 10:55 PM
BOBBYRUBIO
I'll check it out.
Thank you!
Jun 12, 2008 at 6:13 AM
