1994 Honda Civic brake problem
128,000 MILES • 4 CYL • FWD • AUTOMATIC
NATHANIELLUCHT
the brake drum is stuck and wont come off is there a way to get it off.I think the shoe got worn down so bad that the drum got worn in alot.
Nov 5, 2008 at 2:05 PM
KHLOW2008
  • 41,812 POSTS
Hi nathaniellucht,
There is a slot behind the backing plate that you can insert a screwdriver to release the adjuster. However you need a fine screwdriver to push the adjuster tab away to enable adjustment.
Hope you have remembered to release the parking brakes, ;)
Mar 16, 2021 at 4:25 AM
