1994 Honda Civic Blower Motor
15,000 MILES • 4 CYL • FWD • MANUAL
DBACH
Recently my heat will not come on in my vehicle, I have checked all the fuses and still no luck. When I change the settings on my climate control I can hear the damper moving but not air is blowing through the vents. I know most likely the blower motor will need to be replaced, I just am wondering how to test the motor to make sure it's bad. How much do they typically cost?
Nov 10, 2008 at 1:15 AM
KHLOW2008
  • 41,812 POSTS
Hi Dbach,
To test the motor, test for power to one of the terminals and ground the other terminal. If motor works, it is wiring fault. Try giving the motor a few bangs and see if it works temporarily, if yes, the motor is bad.
Nov 19, 2008 at 2:10 AM
