1994 Honda Civic blinkers and hazards
1994 HONDA CIVIC
DRBOBERT
Electrical problem
1994 Honda Civic 4 cyl Front Wheel Drive Manual
when i put on my blinker my hazards flash why??
Feb 5, 2009 at 2:24 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Does the turn signal switch also operate the hazard lights? If so, you will need to use a multi-meter and test the wiring to switch. Switch is probably faulty if this is the case. Otherwise, may need to replace your signal flasher.
Thanks for using 2CarPros.com!
Feb 5, 2009 at 3:31 AM
