1994 Honda Civic Blinkers
169,000 MILES • 4 CYL • 2WD • MANUAL
CMETZLER5
All four (front and back) blinkers will not work. replaced bulb on one blinker and it caused all four to stop working. Hazards work. Headlights work. Checked fuses, under dash on drivers side (under steering column) could not find a bad one.
Mar 17, 2009 at 2:07 PM
F4I_GUY
  • 3,302 POSTS
It is most likely your signal switch on the steering column. Run a diagnostic to see if the switch is functioning properly.
Mar 18, 2009 at 12:32 PM
