1994 Honda Civic a/c light wont turn on
168,000 MILES • 4 CYL • FWD • AUTOMATIC
MARINES
Im having trouble with my a/c system. The a/c button light does not light up when I press it . I moved the fan speed, but it only blows hot air. I replaced a/c compressor, added freon, changed the two front relays on left side near the headlight, I checked al fuses, I also replaced the the temperature control system thats under the radio. The a/c button light does not light up at any fan speed which does not activate the a/c clutch. I also tried a direct electrical wiring to the a/c compressor which made it turn on, so I know that it is working. Im worried that the light does not turn on.
May 27, 2010 at 5:01 AM
KHLOW2008
  • 41,812 POSTS
Hi Marines,
Does bypassing the AC switch turn the compressor on?
May 28, 2010 at 6:19 AM
