1994 Honda Civic AC Clutch
211,000 MILES • 4 CYL • FWD • MANUAL
JOHNNYZARATE
i just replaced the ac clutch because the clutch bearing was damaged. But the ac does not cool no more and instead hot air is released and before the clutch was damaged, the ac was still cooling. Also the ac clutch sparks when it is running.
Sep 2, 2009 at 5:26 PM
KHLOW2008
  • 41,812 POSTS
Hi johnnyzarate,
When the AC clutch is sparking, it is most likely caused by the clutch clearance being excessive. this would not allow the clutch to hold tightly and is slipping. This would cause the non cooling as well.
Sep 13, 2009 at 7:36 AM
