1994 Honda Civic 94 Honda timing belt replacement
TUFFNC
  • 1994 HONDA CIVIC
Engine Mechanical problem
1994 Honda Civic Front Wheel Drive Automatic 188000 miles
does crank pulley bolt losen counterclockwise and come off with ease or do you need a puller?
Saturday, September 20th, 2008 AT 9:13 AM
KHLOW2008
  • 41,814 POSTS
Hi tuffnc,
Crankpulley loosens counterclockwise and is torqued at 150 ft/lbs. It comes off easily.
Sunday, September 21st, 2008 AT 7:44 AM
FIREMECH01
Tuffnc Posted: Sat Sep 20, 2008 6:13 am Post subject: 1994 Honda Civic 94 honda timing belt replacement
Just did on of these, not so easy.
1/2" inpact did not budge the crankshaft bolt, after several attemps I heated bolt to 450 F. With prybar and 1/2" breakerbar still no luck, bought a stronger and longer breakerbar, fabricated a holding fixture to keep the crankshaft from turning and stood on the breakerbar, ( I weigh 260 lbs.) With a little bouncing it gave it up.
Sunday, September 21st, 2008 AT 6:59 PM
KHLOW2008
  • 41,814 POSTS
Hi firemech01,
Sorry I confused you. The bolt is torqued at 150 ft/lbs so you need quite some force. What I meant was the pulley would come off easily after the bolt is removed.
Guess you need a 3/4 " handle to get it out. 1/2 "extensions are too flexible and cannot get the proper strength to get the bolt off.
Other optionj is to get a VERY high torque impact, those that the use for truck tires would be ideal. Btw spray some rust remover and let it soak, might help.
Monday, September 22nd, 2008 AT 8:05 AM
