1994 Honda Civic
CARRIE A. CHECK
Tires and Wheels problem
1994 Honda Civic Automatic
I need to know how to change the rear tire for a Honda civic dx
May 6, 2008 at 1:34 PM
  • 31,937 POSTS
Hi there,
If you wish to replace the tyre on the rim, you will have to visit a tyre shop as special equipment is required to do this. If you wish to change the wheel, place transmission in park, hand brake on, remove wheel trim if fitted and using wheel brace loosen nuts, (don't remove) chock front wheel and place car jack under lifting point (check manual) raise car enough to remove wheel , remove nuts ,and replace wheel. fit nuts and do up finger tight making sure wheel is central, nip up with wheel brace, lower car of jack and tighten wheel nuts, replace trim.
May 6, 2008 at 10:21 PM
