1994 Honda Civic
SALONZO17
1994 Honda Civic
how do i remove the rear door panel on a 94 civic dx?
May 21, 2009 at 8:50 AM
TED-E-DEE
  • 109 POSTS
I B-leive you mean rear hatch ? There are screws along the bottom & on each end, under caps that you remove, then remove the screws. W/ special tool { U-shape end },or small needle nose, find clip locations under panel, { B-tween panel & shell }, & "pop" them out. There are some screws hidden on door panel { center } useually also under caps. Use caution for clips easily broken & panel easily cracks. Once screws & clips removed, lift panel "up"& off. Good Luck !
May 21, 2009 at 11:22 AM
