1994 Honda Civic
GHAMM
  • 14 POSTS
Engine Mechanical problem
1994 Honda Civic 4 cyl Front Wheel Drive Manual
what cylinder heads are compatible with the 1.5
Nov 27, 2008 at 1:17 AM
F4I_GUY
  • 3,302 POSTS
All SOHC honda heads from 92-00 are interchangeable. V-tec or non-vtec.
You have a d15b7, so any d15 head would bolt up, same with a d16z6 or d16y5/7/8. However, the flow characteristics and the ECU's are different, so if you do bolt on a different head than a d15b7 you will need to chip and socket your ECU and have a performance tuner tune your vehicle for reliable fuel economy and maximum power.
I am very well versed in honda swaps and head swaps, so if you have an engine code or want to know what your best option is reply back with excatly what you want to do and I will help you.
Thanks.
Nov 27, 2008 at 8:53 AM
