1994 Honda Civic
COTHRAN64
Engine Mechanical problem
1994 Honda Civic 4 cyl Front Wheel Drive
When replacing the timimg belt, where should I aliign the top sproket - when the bottom pulley aligned with crankcase pointer (TDC)... Shoukl I align the 2 marks on either side of the top sproket with the valve cover sealing surface (with the "up" mark facing up center) or the bottom mark on the top sproket aligned with the plastic pointer???
Nov 15, 2008 at 7:05 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_62.jpg
also check it @ https://www.2carpros.com/car_repair_information/index.php
Nov 15, 2008 at 8:52 AM
