1994 Honda Civic
MARQOROO74
  • 1994 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 206,000 MILES
I have had my engine worked on recently. Replaced the timing parts and timing gear seal. I ran well for a couple of months. But, now the engine light is back on, and the RPM will fall off on deceleration. Do you think I might need a new distributor. I rebuilt this part ab out a year ago.
Wednesday, November 12th, 2008 AT 5:44 AM
BMRFIXIT
  • 19,053 POSTS
Check engine is on this will help pin point the troubled area
need to have the codes read and or pulled 1st
post back with what u have for codes for more help
check fuel pressure check coil check for vacuum leaks
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, November 12th, 2008 AT 5:58 AM
