1994 Honda Civic
225,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBERTOF30
MY QUESTION IS ABOUT THE CONDENSER FAN FUSE BLOWS ,I CHARGED THE AC AND IT WORKS FINE BUT AFTER A WHILE THE FUSE BLOWS, I ALREADY CHANGE 2 FUSES,DOES THE TEMPERTURE SENSOR HAS TO DO WITH SOMETHING WITH THIS PROBLEM?. WHAT DO I HAVE TO DO SO THE FUSES WONT BLOW UP PLEASE LET ME KNOW THANK YOU VERY MUCH
Jul 16, 2008 at 2:27 AM
BOBBYTECH1
  • 49 POSTS
just make sure if the condenser fan is seized causing the fuse to blow!
Jul 16, 2008 at 2:38 AM
ROBERTOF30
hey thanks for the answer but i don`t understand (condenser fan is seized ) can you help me whit this. thank you .
Jul 16, 2008 at 2:54 AM
KHLOW2008
  • 41,812 POSTS
Hi robertof30,
Thanks for the donation.
He means the condenser fan is not working due to seized bushes or internal shorting.
Make sure fan is turning freely and does not emit any noise while in operation. With engine off, use hand to push the fan baldes to see if they work well.
Jul 16, 2008 at 5:05 AM
ROBERTOF30
hey guys, i change the condeser fan , i put i new one and the fuse keep blowing out . help me with this thanks.
Jul 24, 2008 at 3:45 AM
KHLOW2008
  • 41,812 POSTS
Hi robertof30,
Sorry for the late reply.
The condenser fan fuse is shared by the compressor. Check if the compressor clutch coil is bad and is shorting intermittently.
Jul 29, 2008 at 11:45 PM
