1993 Honda Civic Trans problem ??????
CHUGHES4656
Transmission problem
1993 Honda Civic 4 cyl Two Wheel Drive Automatic
My honda will drive fine for about 10 minutes and then it will automaticlly go into a neutral state when
the shifter is stll in gear, it doesnt grined at all or make any noises, the fluid look good and not burnt at all. The funny thing is if you turn the car off and then back on the car will go agian for about 5 to 10 mins and do the same thing.
Nov 1, 2010 at 3:08 AM
KHLOW2008
  • 41,812 POSTS
Hi chughes4656,
Problem is internal. Either the fluid strainer is clogged or there is a pressure leakage somewhere.
Nov 3, 2010 at 1:13 AM
