Hi, I undertand that you can add small wheel spacers to increase the track to a car by a small amout (5-35mm). I own a 93' Honda Civic and plan to build a very wide body kit for it. The body kit will add as much as 30-40 cm not mm, to each side. What wud be the best way to widen the distance of the wheels, could I use a set of axles from another Honda car that is wider than the Civic? If so can you please suggest the right one. Many thanks.
Brad
Brad
Oct 12, 2008 at 1:47 AM
