1993 Honda Civic shakes going over 75 mph
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
SACHIA_11
my 93 honda civic shakes when i go over 75 mph. i know its not the tires, or the front axle because i had all 4 tires replaced and balanced at the same time i had the axle, cv joint, and tire rodes replaced. what else could the problem be?
Jan 30, 2010 at 1:46 AM
KHLOW2008
  • 41,812 POSTS
Hi sachia_11,
Does the vibration occurs only when accelerating or even when cruising at 75 mph or more?
Is it coming from front or rear of vehicle?
Were the front axles replaced new or used?
Jan 31, 2010 at 1:05 AM
SACHIA_11
[quote:58f9f493e3="KHLow2008"]Hi sachia_11,
Were the front axles replaced new or used?[/quote:58f9f493e3]
the vibration happens when cruising at 75 or more
can't tell if it's the entire car that shakes or just the front
front axle was replaced new at kramer tire
Feb 1, 2010 at 7:40 PM
KHLOW2008
  • 41,812 POSTS
Symptoms indicates a possible wheel blancing fault. Get the wheel balancing checked, could have been done incorrectly when they were replaced. Recheck if any of the rims are bent.
Feb 1, 2010 at 9:59 PM
