1993 Honda Civic Radiator on winter time
297,000 MILES • 4 CYL • FWD • MANUAL
LUBRICATE
Simple question.
My radiator is going to be change because it is dusted and it's leaking.
So do I need to add cooling liquid again and again in winter? Will it break something if I don't?
The car is not heating because it's really cold outside here in Montreal.
Thanks!
Dec 13, 2008 at 2:43 AM
F4I_GUY
  • 3,302 POSTS
Are you asking if you will need to re-fill your coolant after replacing the radiator? If so, yes you must definately do. Your radiator holds most of the coolant.
Dec 13, 2008 at 9:34 AM
