1993 Honda Civic OVER HEATING
ISHCAIN1
  • 1993 HONDA CIVIC
Engine Cooling problem
1993 Honda Civic 4 cyl Front Wheel Drive Automatic
MY CAR OVER HEATS AT LOW SPEEDS BUT COOLS DOWN AT HIGH SPEED. I HAVE A NEW WATER PUMP, THERMOSTAT AND RADIATOR. I HAVE NO LEAKS AND THE FAN COMES ON AND OFF AS IT SHOULD.I THOUGHT THAT THE COOLANT SWITCH WAS BAD SO I REPLACED IT TWICE. NO CHANGE. WHATS MY PROBLEM?
Tuesday, December 9th, 2008 AT 5:09 PM
F4I_GUY
  • 3,302 POSTS
Have you properly bled your cooling system?
If that checks out, I would ensure that it is not your thermostat when it is overheating. Also, when it is overheating your fan should be on. If it's not, you should a proper diag. On your fan system.
If everything else checks out, you may have a possible headgasket issue. They are somewhat common on those vehicles. Are you loosing coolant?
Tuesday, December 9th, 2008 AT 5:29 PM
