1993 Honda Civic Need Info Please !
JAMES369
Engine Mechanical problem
1993 Honda Civic 4 cyl Front Wheel Drive Automatic
My car is 93 civic 1.5L. 3 days ago the battery light was on and yesterday the car didn't start. its only start with a boost. I changed the carburetor but still have same problem. It starts only with boost and engine turn off when i take out the booster. Need little help please. Thanks in advance..
James
Montreal, Canada
Apr 26, 2009 at 10:39 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:491b9cd464="james369"]Engine Mechanical problem
James
Montreal, Canada[/quote:491b9cd464]
Since it will only start and run while you have another vehicle attached it is most likely your Alternator.
Apr 26, 2009 at 10:42 AM
JAMES369
Thanks a lot for your answer. That would really help me a lot but i already changed the Alternator too yesterday. Do you think there might any problem with wiring of Alternator ? hanks again in advance.
James
Apr 26, 2009 at 3:08 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:b1cba8a823="james369"]Thanks a lot for your answer. That would really help me a lot but i already changed the Alternator too yesterday. Do you think there might any problem with wiring of Alternator ? hanks again in advance.
James[/quote:b1cba8a823]
Hey James,
Check Fuse #12 (15amp blue) in the fuse block under the driver dash for the Civic.
Check Fuse #24 (15amp blue) for the Del Sol.
Apr 27, 2009 at 7:16 AM
