1993 Honda Civic my heater stoped working can you help me
98,000 MILES • 4 CYL • 2WD • MANUAL
LENNY11717
ok here it goes i has a 93 civic ex and the heater stoped blowing and the milage gauge and temp. gauge stop working alos ive checked and changed every fuse in the car and i still cant seem to figure out what it is. and also with the same car i keep over heating. ive ran a manual swith to the fan but at least twice a week i have to put antifreeze in the car ive had the car in the air and ive seen the antifreeze dropping from where the bottom of the timming belt cover a couple months ago but i dont see it dripping any more but now when i put anifreeze in the car when it reaches the top of the radiatior its brown what could this problems be. can you please help
May 29, 2008 at 4:27 PM
KHLOW2008
  • 41,812 POSTS
Hi lenny11717,
The antifreeze dripping at the timing belt area means either the water pump or the pipe behind the pump is leaking.
If the blower don't work, you should check for current supply to the blower motor.
The odometer, fuel gauge, temp gauge all uses the same fuse which is located in the fuse box under the dash.
Another of your thread mentioned wring problems, so I guess you are gonna need to replace the whole dash wire harness to solve the problem.
May 30, 2008 at 6:06 AM
