1993 Honda Civic manual transmission
185,000 MILES • 4 CYL • 2WD • MANUAL
SCROUSE
This morning, daughter driving and car quite moving. Engine races, but won't move. Able to shift thru the gears, but acts like clutch is not engaging. Hyd. clutch looks to be working. Linkage moving correctly.
While running, you can shift into any gear. Clutch in and out just fine, but car wont move. Nothing spinning (CVs).
Has been working fine. No clutch slippage or anything like that.
Acts like something broke internally on the transmission, but wondered if you had any ideas.
I'm about to split the transmission from motor (had done this before to change clutch on other civics) but wondered if you knew of similar problems.
Steve
Dec 16, 2009 at 3:05 AM
F4I_GUY
  • 3,302 POSTS
Put the vehicle in fourth gear and try and drive the vehicle. If the motor gets revv's up, the clutch/pressure plate is slipping and must be replaced.
Dec 16, 2009 at 12:17 PM
