I have a 1993 Honda Civic with a 1.5. I jusrt replaced the motor after it overheated and started to smoke. After replacing the motor, I keep getting a rolling Idel. I have replaced one of the Idel control sensors and cleaned the other. I also got a used MAp sensor as well. I can not seem to get it to stop. I have checked all vaccum lines and it hold 8psi.
However when I sprayed carb cleaner on the the 4 piston intake area it started to pop. So I replaced the PCV thinking it may be taking in a little cleaner into the area.
Mar 22, 2008 at 4:39 PM
