1993 Honda Civic heater stopped working
201,000 MILES • 4 CYL • 2WD • MANUAL
HONDAMAN93
My heater was working just fine untill yesterday all of a sudden it quit working for no reason i checked all of the fuses and they are all fine. I was wondering what it could be. Any advise would be very much appretiated with your feedback thanks
Dec 20, 2008 at 12:38 PM
KHLOW2008
  • 41,812 POSTS
Hi hondaman93,
You mean the air is not blowing?
Dec 21, 2008 at 1:51 AM
HONDAMAN93
when i turn on the switch nothing happens no air no noise nothing
Dec 21, 2008 at 9:38 AM
KHLOW2008
  • 41,812 POSTS
Hi hondaman93,
So the blower fan motor is not working.
We shall start with that first. Start engine and turn on switch. Use your hand to bang the blower motor housing under the dash on passenger side and if fans starts working, the motor is failing and it's time to replace it.
If above fails, hope you have a test lamp and is able to do some wiring test.
With ignition switch ON, test for power supply to the blower motor Blue/White wire by back probing it. If power is available, back probe the other wire, Blue/Black. If power is not available, the motor is bad.
Dec 21, 2008 at 11:44 PM
VICMADRIGAL
Hello, my heater it’s not working, it’s just blowing out cold air.
Dec 22, 2021 at 11:27 AM
SQM
  • 6,383 POSTS
There are a number of reasons why the heater might not work and only blow cold air.
It could be due to being low on coolant, having a stuck open thermostat that is not allowing the engine to warm up properly, faulty blend door actuator that is stuck on the cold side, it can also be due to a clog in the heater core which is restricting the flow of coolant through it.
Take a look at this guide, it covers the typical issues:
https://www.2carpros.com/articles/car-heater-not-working
Go through this and let me know what you find or if you have any questions.
Jan 3, 2022 at 12:38 AM
