1993 Honda Civic Heater & AC do not work
173,000 MILES • 4 CYL • 2WD • MANUAL
MEHALT
I bought my Civic for getting to and from work since it gets great gas mileage. I have had it for 2 years now. The AC and Heat never have worked, not something I was terribly concerned about, but now would like to get it working. The fan does blow, and the Refrigerant was charged last year - the AC just never worked even after the charge. Note I am more concerned with getting the heat to work, but the problems might be related??
I am capable of doing some minor troubleshooting and car repair, but by no means am I a car mechanic.
Jan 6, 2010 at 1:59 AM
DOCFIXIT
  • 18,828 POSTS
Hi Are heater hoses hooked to core? Is thermostat working? Do hearter controls work / Mode select?
Let me know
Thanks for donate
Jan 7, 2010 at 1:48 AM
MEHALT
I will check the heater hose and make sure it is connected, and there are no kinks.
Can I assume the thermostat works since the car has had no history of overheating during the past 2 years I have owned it? Also, the temp gauge does come up once it is running for a little while.
I will also do some checking on the heater controls.
I will let you know what I find once I have completed,
Thanks for the suggestions.
Drew
Jan 7, 2010 at 2:32 AM
