1993 Honda Civic engine knock
DERYION10
Engine Mechanical problem
1993 Honda Civic 4 cyl Front Wheel Drive Manual
i have a engine knock and wanted to know if that means that i need a new motor or is that something that can be fixed
Feb 14, 2010 at 2:55 AM
F4I_GUY
  • 3,302 POSTS
Your best bet would be to have a mechanic listen to the knock to determine what the problem is. You may not need to replace your engine. For example, if it's a rapid ticking, it may just mean that you need a valve adjustment.
Feb 14, 2010 at 4:09 AM
