1993 Honda Civic civic brake indicator light turned on
JSASS
Brakes problem
1993 Honda Civic Front Wheel Drive Automatic
I've only ever seen this light on while I had the parking brake on, but it appeared to come on while I was driving. My brakes still work.. Also, its only on when my car is angled uphill. Downhill it goes off. Help please?
Aug 2, 2010 at 9:52 PM
EDWARD.S
  • 166 POSTS
Hi,First have your brakes Checked.If your brake Lining Is low ,this can make the light come on.Second, If brakes are ok,then check the master cylinder ,and see why it's low on fluid, also have the brake system checked for leaks.
Hope This Helps You,
Good Luck
Edward S.
Aug 2, 2010 at 10:17 PM
