Is there a A/C fuse inside the car if so which one is it because I can not find out which one it is?
Jun 10, 2008 at 6:44 AM
JUICE740
MEMBER
[quote:7be1f4ad27="Juice740"]Air Conditioning problem
1993 Honda Civic 4 cyl Front Wheel Drive Automatic 106455 miles
Is there a A/C fuse inside the car if so which one is it because I can not find out which one it is?[/quote:7be1f4ad27]
Jun 10, 2008 at 6:46 AM
KHLOW2008
✓Experienced Mechanic
Hi Juice740,
Yes and it is the rear window defogger relay, ABS motor relays. It is used for energising the main AC relay when Ignition is switched on.
No 13 (7.5 A) if my data is correct.
Jun 10, 2008 at 7:27 AM
NICK'S WRENCHES
MEMBER
1 POST
You should also check you a/c relay under the hood in the fuse box, seen several of these gone bad in the last few weeks.
