1992 Honda Civic water pump and seal
CIVICSIX
  • 10 POSTS
Engine Mechanical problem
1992 Honda Civic 4 cyl Front Wheel Drive Automatic 170,k miles
i gotta change out my old water pump. the old one is leaking and just done in better words. but my real problem is i dont know how to change the timing seal. i was told any time you change the water pump theres a timing seal that must be replaced also.Im not exactly posistive if the mechanic said it was a timing seal oer timing belt because he had a heavy accent. but i really appreciate if someone could tell me how do i replace the timing seal or belt[img:ffce047021]http://www.2carpros.com/forum/automotive_pictures/325548_1237854718684_1.jpg[/img:ffce047021]
? theres a pic uploaded of my engine to show whats there if needed to direct me by. thanks again. civicsix
May 18, 2009 at 5:23 AM
F4I_GUY
  • 3,302 POSTS
He meant timing belt. There is no 'timing seal'. There are crank and cam seals that you should replace only if they are leaking. There is also a seal for the water pump that comes with the new part that you should obviously replace. That's about it.
May 18, 2009 at 6:07 AM
CIVICSIX
  • 10 POSTS
Thanks. i really appreciate it. good day to you
May 18, 2009 at 12:04 PM
