1992 Honda Civic top brake light
IZZO52
Electrical problem
1992 Honda Civic 4 cyl Two Wheel Drive 204890 miles
changed bulb but still doesnt work. is their a fuse, its the brake light by the rear window
Jun 17, 2009 at 6:16 PM
F4I_GUY
  • 3,302 POSTS
First check to see if you have power and ground to the connector. If you are missing power check your fuses and to see if the wire was broken off in the hatch harness (very common)
Jun 18, 2009 at 11:04 AM
